I just completed my first D16Z6 build using a stock block bored to .5mm over and crank bore checked and polished for uniform clearances. Stock D series rods ARP rob bolts and head studs. P29 YCP pistons 75.5mm and NPR pistons and rings 75.5mm gapped and clocked. I used plastigauge confirming all rod and main bearing clearances with ACL bearings at .0015.
Upon startup blue smoke completely filled the garage and continued until engine shut down on its own. I pulled the plugs and of course all 4 are covered in oil. Oil on the ground behind the tail pipe and even oil dripping from the header to exhaust connection.
I would assume my rings are incorrectly gapped, installed upside down, or clocked incorrectly. My problem is when I break it down if everything looks like when I put it all in, how do I know what the problem is?
If anyone has any ideas I'd appreciate the input.
Thanks
Thanks
