1 - 4 of 4 Posts
Does anyone by any chance know what color the STD bearings would be closest to? I have found lists for the thickness of each color but i cant seem to find a thickness for the aftermarket STD bearings and i have ran into bearing clearance issues due to the lovely array of bearing sizes Honda likes to use in stock applications.. Just basically looking for an interchange guide..
This is from EP3Moschini:
Main Bearing thickness by color
Blue 2.013-2.010 mm 0.0793”- 0.0791”
Black 2.010-2.007 mm 0.0791”- 0.0790”
Brown 2.007-2.004 mm 0.0790”- 0.0789”
Green 2.004-2.001 mm 0.0789”- 0.0788”
Yellow 2.001-1.998 mm 0.0788”- 0.0787”
Pink 1.998-1.995 mm 0.0787”- 0.0785”
Red 1.995-1.992 mm 0.0785”- 0.0783”
Rod bearing thickness by color
Blue 1.510-1.507 mm 0.0594”- 0.0593”
Black 1.507-1.504 mm 0.0593”- 0.0592”
Brown 1.504-1.501 mm 0.0592”- 0.0591”
Green 1.501-1.498 mm 0.0591”- 0.0590”
Yellow 1.498-1.495 mm 0.0590”- 0.0589”
Pink 1.495-1.492 mm 0.0589”- 0.0587”
Red 1.492-1.489 mm 0.0587”- 0.0586”
Tried to post link but it wont let me do to my post being low..
Meat Popsicle
91 CRX Si
Keep in mind that each bearing in a standard bearing set may not be exactly the same size.
If you’re building the engine yourself and have plenty of time, you can swap bearings around and use plastigage to see what combination works best.
1 - 4 of 4 Posts
