1 - 6 of 6 Posts
So, I've done some searching for the past week and have came up empty handed. The problem: my car is putting down 395 lb/ft of torque at the front wheels, I keep getting shaft separation in 4th gear at the track or on the highway.
I'm hoping to find a 5th gear handcuff made for D16 transmissions specifically, anyone know where to find one at?
Thanks. I figured if anyone would know, it would be you. Guess I'll just keep replacing parts until the engine gives out and then build a B.
I don't have the equipment to fabricate the parts needed for the CG swap and the only place that I know of that made a complete d2b kit for the 6th gen Civic was Speed Factory. Theirs is long discontinued of course.
I considered getting an Evolution kit, but I would still need to source the mounts somewhere. Oh well.
Good info again. I Laughed at Dans old post on H-t.
Anyone got the link for the CG trans write up on a D16?
Have Aquafina make a cuff.
The shafts don't separate as much if the bearings are tight and the hop is gone.
1 - 6 of 6 Posts
