1 - 3 of 3 Posts
hi ..never wanted this to be a new thread . i tried searching around for a some info none found so .. any way let me know if this question been ask before if not some one might be able to shed some light on this question.
im planning on doing a d15z5 to d16y8 swap.
my car's a 96 civic 4 door ek3 . is this engine available in the states ? when i bought the car sometime ago . i was cleaning out the cabin and found a singapore 5 cents so i thought its prolly been imported ... maybe ... ok , this d15z5 engine has the tb on top of the intake manifold bear that in mind , has a sinlge wire o2 sensor and only two plugs in the ecu ... the d16y8 came out of a 97 delsol 4 wire o2 sensor im not sure which ecu it uses ... so does anyone know ? .... secondly ok the uk civic/delsol uses the immoblizer type ecu. so what should i be doing to pull of this swap ??
HONDA CIVIC
As your chassis is from the same generation that the Y8 that wanna put in ..is a direct swap.... , just run 3 plus wires to the lambda sensor to run a 4 wire one...
About the ECU , that is an OBD2A , you need to use the one for the engine that you wanna install , but need to open and remove the IMMO chip , so you can start the engine ...in future you want to buy from Rywire , a chip to trick the IMMO/ECU and erase the warning light of the IMMO from your dash ...
1 - 3 of 3 Posts
