1 - 4 of 4 Posts
95 civic ex coupe
so.. im gonna use my spare d15z1 vtec-e shortblock and put a y8 head on it.. i did the zealautowerks comp calc it said it should be 8.04:1...
i know thats pretty low but it should be ok with boost..
just my concern.. i know the z1 uses a 1.6 rod length 137mm but i dont know if the rods are as strong as the 1.6 rods.. if anyone has info on that would be great..
also is 8:1 too low for the setup?
any info/help would be cool.. thanks
they are not as strong as D16 rods, but someone went 13's with that combo.........
1493cc, not sure of his username on here......
95 civic ex coupe
thanks bone...
so 10psi on a t3 .42 .48 should be fine then... thats what i was using on my z6/y8head shaved 20 with the a6 .046 hg
yeah and you'll have a nicer r/s ratio something like 1.62:1
so this combo should be a bit better than a stock d15bx
and Joe (1493cc) ran 13 flat in a 6th gen sedan mind you.
1 - 4 of 4 Posts
