1 - 4 of 4 Posts
when I rebuild my engine d15z1 d16z6 head motor together. I removed the bolt engine mount driver side timing belt engine mount that has two bolts.
I reinstalled and hand tightened the aluminum stripped they always seem to strip just hand tightening and not even quarter or so turns. but Ive already installed time serts and it is solid.
The problem I need the engine mount torque specs.
ive downloaded a pdf of the service manual It don't seem to show any torque spec of that particular mount.
timing belt side engine mount near the cam gear. and those two bolts. that are 14mm?? please
does anyone know? ive torqued it to 50 ft lbs but I want to make sure.
whats the exact torque spec.
thank you dseries.org in advance?
40 ft/lbs
Torque to 30 first, if you are worried about breaking something.
wont hurt to have a small dab of blue thread lock
Reactions: slo_eg8
1 - 4 of 4 Posts
