1 - 7 of 7 Posts
I recently swapped out my stock D15Z1 from my civic VX hatch for a D16Y8. I'm using the P28 ECU, stock wiring harness, and stock dizzy. the motor starts but i probably need to do the timing on it. I'm getting the code 41 because i haven't wired the right O2 sensor yet. but other than wiring an O2 sensor and switching up the MAP sensor wires (from what i noticed in the wiring diagrams), Is there anything else i should be aware of?
W
first thing is a p28 ecu is not the y8's ecu also the p28 ecu i made for one o2 and the y8 has two o2 sensors.
W
yea chipped. come on man d16z6 is a diffrenet map then the map for a d16y8.
1 - 7 of 7 Posts
