First of all, I'm not sure if this is the right place to post this, its been a while since I've been here, so mods feel free to move it where it should go.
The problem I have with this is I'm using a VX engine harness in a 93 EX. As some of you might know VX has one extra plug at the passenger side shock tower, as well as an EGR valve and a 5 wire wideband o2 sensor. I've swapped a z6 into a VX but never the other way around. I dont know which wires to disregard and which to move or leave alone. I really need help getting this done..
I'm planning on using the stock VX po7 ecu.
If anyone has a GOOD wiring diagram for both models maybe I could figure it out. My main concern is the shock tower harness/plugs and making the 5 wire o2 work. I dont see how I can get the EGR valve to work so, I'm prepared to live with a CEL for it.
Any help is greatly appreciated!! I'm at a standstill. And sorry about the long post but hopefully I gave all of the necessary info. Thanks in advance.
