1 - 7 of 7 Posts
toytoa supra
ok guys here is what ive got. i bent the valves in my d15z1. I have a spare d15b7 with a massive rod knock and i have a jdm d15b with a locked up bottom end. regardless, the pistons are good in the b7 and d15b. I have a z6 head that i milled .075 off of. Now to the real question. will the d15b pistons work in the z1? i have searched and searched but no deff answer. If they will work then i am gonna put the milled head on the z1 with the d15b pistons. or with much milled off of the head will the head work with the z1 pistons?
d15b rods wont work on the z1 crank but if you get the pistons swaped over to the z1 rods it will basicly be a d15b bottom end, as they use the same length rods but differnt journal size
^^^ Hatch addict wouldn't this depend on which d15b he's got. There were more than one and I was thinking one is Identical to the y7 but also called a d15b
well yes there are like at least 4 different versions, but i ASSumed that he had the single stage vtec one with the big rod journals but i guess i shouldnt have assumed anything. yes you are absolutly correct it would depend on which version he has of the d15b
toytoa supra
well the only running motor i have is the z1, its a single stage vtec e, it runs 12 valves then 16 when the vtec is engaged. but the valves are now bent and i just want a peppy sohc to play with. i already have a z6 head that i just milled .075 off of, which is a hell of a lot. soooo according to the d series comp calc i should be running a comp ratio around 9.3/1 with the z1 pistons. but i was curious to know if the d15b pistons would work. and according to you guys they will. so thanks guys for the reply. any ideas? let me know
Run teh d15b pistons in the Z1 block, and run teh d15b head
now you have a full d15b
1 - 7 of 7 Posts
