1 - 1 of 1 Posts
is this true?
"all d15 cranks are the same. the different rod to stroke ratio from the d15z1 come from the longer rods and shorter pistons."
i believe it to be true/accurate... so .... now look at:
http://www.knology.net/~jediklc/D.htm
http://www.heeltoeauto.com/dseries/dseries1.html
according to the specs there, the ONLY pistons that will work in the d15 with 137mm rods and have enough clearance are the PMS/PLR/PLM. all of which have a 27mm comp height, which is .75mm less than the z1.
all the d16 pistons have a comp height of 29-30mm, which will cause the pistons to stick out of the head by over 2mm.
so, if my theory is true, only the 01-03 civic d17 pistons will work in a d15 with d16 137mm rods.
anyone? please post comments.
1 - 1 of 1 Posts
