1 - 7 of 7 Posts
Hello
I have a 2005 Civic which comes with a D15Y3. It's like the D17 but a 1.5L variant. It's Non-VTEC and is an automatic. The car is drinking fuel like a V8 and it's really hurting my pocket. I've cleaned air filter so far and cleaned my plugs but it seems to make no difference. My driving is really serene and the tranny shifts well before 3k rpm.
68 Camaro
o2 sensor, clogged injectors, sticking brakes,
with out any symptoms we cant help
The car runs nice so I'm pretty sure it's not the brakes.
I'll have a look into the injectors and O2 sensor.
Apparently the car does not have an O2 sensor because I really don't see one anywhere near the exhaust :/
What do you mean it runs good? Aren't you talking about poor gas mileage? Get that bitch in the air and start poking around, should be easy to find if you inspect each system listed above.
it isn't supose to have this poor fuel econemy my friend used to have tons of mpg with he's d15y2 even with vacuum leaks, sorry i cannot help you much but i hope you fix your problem and check the things cmgreen noted
1 - 7 of 7 Posts
