1 - 3 of 3 Posts
My D16y8 Trans housing has a broken mounting stud for the mount. So I took off a B8 outer tranny housing to swap with the Y8 and the Y8 is quite a bit different. Is there anyway to swap these or am I just stuck finding a new Y8 housing?
B8
Y8
if Im not mistaken, the stacks are different between the 2, or the bearing is bigger in one. something along those lines
Fix the issue, but you will need to find the three missing balls from the Y8 case you lost since detent balls/springs/bolts weren't removed when you split the case.
1 - 3 of 3 Posts
