1 - 3 of 3 Posts
im doin a mini me swap witha d15b7 block z6 head what timing belt should i use?
use the belt for the z6. use the z6 dizzy as well... just use the parts that go with the head that you are going to use and you should be just fine
good to see some more indiana people rockin out :holla:
I heard something about replacing the TB tensioner, is this true?? wich one should I use??? on the same set up...(b7/z6)
1 - 3 of 3 Posts
