1 - 20 of 26 Posts
AUSDM EG8 Sedan
hey all
i have a D15b7 with 300k kms on the clock, it has a D16a6 cam and basic bolt ons ... always looked after, serviced well, fussed over etc
after having a bumpy ride for a while, i checked my shocks and they were dead, so i replaced them ... but the bumpy ride was still there ggrrr
after driving normally for 5mins (didnt even get to put my foot down) i was pulling out onto a highway in 1st gear and the car just started free revving ...
the transmission feels fine, the clutch still has spring, and the engine still runs ... but when i release the clutch while in gear it just revs with no drive to the wheels
i got towed back to my mechanics house and he pulled it apart again to have a look at it ... he said that the input shaft could be dead but he will have to investigate further, this could account for the bumpy ride i was getting
either way he told me to start pricing up transmissions from the local wreckers (im in australia lol)
whats the best transmission i can get for this engine? what will fit?
i tried a quick search but my search-fu is weak
if someone could point me in the right direction i would be greatful =)
95 Solvic, 93 dS si
personaly i prefer the trans off of the si sol. a little closer gearing, eventually however im going to order a set of custom 5ths from ssr for better fuel mileage and run a mfactory lsd in it.
Red '95 EX
well you could pretty much match up any Dseries hydro tranny. if that b7 is the stock motor then stock replacement would be the dx tranny. but if your going to replace it you should just buy an ex/si tranny and call it a day. shorter gearing but wont loose much mpg's. hell of a lot more fun tho to drive. cant remember the actual tranny code for the dx but ex/si is B000 s20.
AUSDM EG8 Sedan
please tell me engines ... not car models
i live in australia and the only thing thats the same is the engine
its a 1.5ltr ... i dont car much about fuel economy ... its always still gona be better than my WRX lol
i just want a stronger box with better performance
so what engine is in the ex/si?
AUSDM EG8 Sedan
ok so im thinking D16y8 box with exedy clutch kit and fidanza light flywheel ... will this work?
AUSDM EG8 Sedan
just got a quote from local wrecker ... $770AUD for D16y8 gearbox =/
i was expecting more along the lines of $300 =/
AUSDM EG8 Sedan
yeah i guess ill have a look around on ozhonda.com ... or just get my original box fixed and wear the cost =/
AUSDM EG8 Sedan
Discussion Starter #15 (Edited)
still looking for a gearbox - mine is pretty well dead now
not too bad for 310 000 kms
still trying to suss out what to do
there are some JDM SOHC D15B VTEC 5spd manuals on ebay - will these bolt up?
EDIT - trans code: S20-2032459
AUSDM EG8 Sedan
Discussion Starter #16
ok so im going to pick up a S40 gearbox tomorow
its from a 96-00 EK VTI which in australia have D16y5 ( afaik same as D16y8 )
is there anything i should know before i drop it off at the mechanic for the swap?
also should i do clutch and flywheel now while its all off?
Y5 USDM tranny will be slow. Y5/Y8 USDM tranny's are the same case, one has crappy 3.72 FD and long gears, other (Y8) has the desired 4.25 FD and normal spaced gears.
Know what you are buying!
AUSDM EG8 Sedan
Discussion Starter #18
hrm ... how can i tell the difference?
so if i get the Y5 it will be worse than my stock one?
AUSDM EG8 Sedan
Discussion Starter #20
thanks so much for this info - i hate being a noob
A) is it hard to split it open?
B) how many teeth should the better gearbox have?
1 - 20 of 26 Posts
