1 - 11 of 11 Posts
Hello guys, so I have a 93 Civic with half dead D15B7 and I got my hands on wery cheap D15Z8 (economy vtec). Guy, which I bought it from gave me engine, P9l ECU, fuel rail with injectors, wiring that goes from from ECU to right front strut tower and VTEC solenoid. My questions are :
1. Will I need distributor from the Z8?
2. Will the wiring be direct fit to engine harness or will i need OBD 1 to OBD 2 conversion?
3. How do I wire the vtec?
4. Anymore suggestions?
Thanks in advance :)
ECU is directly from the car (P9L, not P91). Also the VTEC is not 3 stage, only one solenoid on engine.
D15Z8[edit]
  • VTEC-E
  • Found in:
    • 1997–2000 Honda Civic LS (MB3, MB9), (European Market)
      • Displacement : 1,493 cc (91.1 cu in)
      • Bore and Stroke : 75 mm × 84.5 mm (2.95 in × 3.33 in)
      • Rod Length : 137 mm
      • Deck Height : 207 mm
      • Compression : 9.6:1
      • Power : 114 hp (85.0 kW, 116 ps) at 6500 rpm
      • Torque : 95–99 lb·ft (13–14 kg/m, 128-134 Nm) :confirm? at 4500 rpm
      • Head Code : P2J P2M
      • ECU Code : P9L
      • VTEC Switchover : 4000 rpm
      • Valvetrain : SOHC VTEC-E, 4 valves per cylinder
        so its basically a vx/hx head?
Discussion Starter · #7 ·
The engine went 27 years basically only with oil change. Whats the idea behind mixing Z8 block with B7 head? It wouldn't have that " I'm saving for B swap" fuel economy VTEC 😂
1994 turbo hatch
lol true true.
i just hate obd2 and will do anything to avoid it. especially in an obd1 car.
i wonder if a z1 ecu would run it with a dizzy swap?
Discussion Starter · #10 ·
Guy gave me the distributor as Well, so i think it depends on the wiring so heres another question: 1. Where to get OBD I to OBD 2 converter?
2. Where to wire the VTEC solenoid.
1994 turbo hatch
i have a jumper. looks like something you could find on ebay
1 - 11 of 11 Posts
