1 - 9 of 9 Posts
99 Chevy s10
I Have a stock d15b7 I fresh into a honda of my own i was wondering if you can make it a vtec or would i have to upgrade the block to a d16z to get it done if i can use my block what head, injectors and intake manifold would i need also would the wiring be hard to do myself.
Certified O.G.
A Shitbox
This has been done SO many times. Search around on here and you will find EVERYTHING you need to know about it.
Try searching the words "mini me"
:trysearch:
You can do a d15b7 vtec but I wouldnt recommend it. You might as well just swap a whole z6.
99 Chevy s10
about how much would a full z6 swap cost range and would it be direct bolt in and go
300-500 for complete z6 swap with ecu and evrything u need for the swap. it is a complete drop in and go. all u need to do is hook up vtec.
99 Chevy s10
when you hook up vtec all they do is soder ac couple of wire to the ecu or do you have to get it tuned
1 - 9 of 9 Posts
