My ej2 d15b7 loses all power and stutters really bad if u push the throttle more then 10%. This is worse when the engine is at operating temperature.
I tried checking the engine codes but when i connect the two pins the engine light just stays on. When the pins are not connected there isn't a engine light.
I switched out the o2 sensor for a different one.
I also cleaned up the connector on the thermostat housing.
