Nope, its just a regular P06 .bin, I spy no changes to it.i usually just export the p28 maps. open the p30 rom and import the p28, then disable vtec and tune the low cam. its a couple degrees less timing than you would normally run, but that can always be changed
i have had this bin saved on my computer for a while now. looks to be a stock p06 bin with fuel pulled and timing added in the cruising portion of the map for better fuel mileage. check it out if you like
no offense, you obviously dont know what you are looking at...Nope, its just a regular P06 .bin, I spy no changes to it.
right on :TU:I know that .bin, it is the one Blundar did for me for my MPG monster![]()
sweet. a real p06 bin that can be modified or boost added :TU:check this out...
i took, stock p06 map... export fuel/timing
open p30, import fuel/timing from p06
remove knock, eld and injector test
rev limit 7500
launch control a 3700
full throttle shift 7200
shift light 7000
removed checksum
added quick datalogguer
add boost tool
but injector are still 240cc
