I have a new engine mount for my left upper mount. The problem is it is meant for the D15B7 or D15Z1 2-bolt style. Will it bolt right up to my D16Z6 block (the metal piece that bolts into the block)? It is a Hardrace mount...
The 92-93 Civics with the D16Z6 came with a 2-bolt Driver side mount
The 94-95 Civics with the D16Z6 came with a 3-bolt Driver side mount (same as the 94-01 Integra)
I am thinking about hitting up the junkyard to try and find the 2-bolt mounting bracket so I don't have to return my engine mount kit from Hardrace.
Hopefully the bracket will bolt right up (I heard the timing cover might be a little different...)
Ok so I’m trying to tension the power steering pump where it needs to be and realized the car didn’t have part of the items needed to do so.
My question is what other piece do I need to complete this so it will stop squealing randomly?
Portion missing is piece that the wingnut bolt threads into...
So I'm going to start that I need a new starter and dizzy for sure but cause I hook up a z6 harness to a y7 block ? And I'm thinking about just getting a z6 block and putting it in
Need a second opinion here:
I have an 89 CRX Hf that had working AC, not amazing, but it worked. I assume it was R12 as there were no converter nipples going on.
A while back someone hit let head on, broke the radiator and mangled the condenser, but didn't rupture it.
I decided since I was...
Hey all,
Long time reader, first time poster.
So, I have a 1995 Civic Ferio Vi, with a D15B (two stage vtec) engine in it. Imported from Japan, so all JDM parts.
But... Something backed off the bolt on my main pulley (AKA harmonic balancer), and it got damaged. So, now to find one.
Partsouq...
