1 - 6 of 6 Posts
sol
ok my del sol d15b7 needs injectors any one know what cc they are?
i have a set off mt 97 civic a d16y8
will they work in my d15 or be to much fuel i know there 240cc`
sol
ok so as long as i have the plug off the 97ex they will work?
i dont think they have the same cc ...d15b7 i think uses less gas it would work but your car might run a lil rich not much i had a jdm d16 and i put ls injectors and people said it was the same thing and it wasent it was running rich same thing happend with my ek ls motor i put the d16y7 injectors and it ran lean it will run it but like i sead might run rich you can always try you can hack the injectors to fit or get the plugs and wire them to your engine harness but if i where you i would just run to the junk yard and get the right injectors.
1 - 6 of 6 Posts
