1 - 7 of 7 Posts
hi i was wondering wat else i need to complete my conversion. I already have a crx si manifold a dpfi to mpfi harness and a z6 head. wat else do i need to complete the conversion.
i wanted to try and keep it OBD0 so i was just going to wire the vtech to a switch do u know if i can use a crx si distributor
'95 Civic dx
vtech? or vtec? just a heads up fix ur shit before people start their bitchin
obd1 ftw! its worth it TRUST me... plus if u end up tuning it crome is the way to go
go obd1 for vtec, unless you want to mess around with a ps9 auto ex ecu, but I bet that would be more difficult.
Other parts needed: The d16z6 dizzy (obd1), p28 ecu (obd1), fuel rail and injectors (go obd1 so no need for resistor box), 4 wire o2 sensor, z6 head gasket, intake and exhaust manifold gaskets, z6 spark plugs and leads, new head bolts.
If you are keeping your existing wiring harness you'll also need to run extra wires to your O2 sensor, vtec solenoid and extra injectors.
1 - 7 of 7 Posts
