1 - 7 of 7 Posts
i would say id you wanna stay with a d-series motor ... spend a little more money and swap in a d16z6 ... and sorry im not sure if its just one chasis to the next ,,,
yes, you can use the A6 injectors. the ecu is a pm-6, for an auto use the ps-9. both will run a little rich. also get the A6 cam, it will be half a tooth off on the cam timing, but just use the cam-gear from a Y7 or a Y8 to correct for this.
1 - 7 of 7 Posts
