1 - 2 of 2 Posts
My oil pan was dented pretty bad in the bottom from a PO. there is a drain hole about 1" by 1 1/2" in it stock and I drilled another about the same size directly across from it on the intake side of the engine.....and was able to pound out the dent using a 1" diameter brass punch and hammer.......I know these baffles are there to control oil during acceleration, braking, and cornering........my question is the hole I drilled going to be enough to cause oiling problems
i guess i need to mention I drill the hole through the baffle just in case anyone misunderstood..........any thoughts?
1 - 2 of 2 Posts
