1 - 2 of 2 Posts
Im making mini me.
car has coilovers, dc2 braking, nice interior.
Engine:
Head z6 ported and polished, valve work.
ported and polished z6 tb.
polished y8 manifold
stock exhaust for start.(will be upgraded afterwards as i have my car runing)
cr will be around 10.7
arp head studs
chiped ecu
car is stoped for 2 years, im thinking if i should do something else on mods.
i tought about boring but not much gains for the money (boring+ pistons+ troubles)
cams looks a little overkill or also not worth the money.
its a for daily driver but would like to reach something around 150hp (maybe thats too much if i want to have low gas consumption)
i have seen much posts but still struggling if i should realy buy cams or if they are not worth for D15.. i want to keep some decent fuel consumption but put this engine running funy.
any ideas ? specialy about the cams... oem z6 or aftermarket?
i would still like to ask about turbo fuel consumption (still im not going turbo at least for now)
D-series Janitor
Front Engine Dragste
Unless you are in boost all of the time, the MPG with a turbo isn't much less than a naturally aspirated car and it's usually better all things considered because the power is added through boost instead of with overlap and RPM giving the car more low-end torque.
I wouldn't bother with a cam yet until you did the turbo and got all of that sorted out via tuning. If you are trying to go the N/A route then really that is your only option.
1 - 2 of 2 Posts
