1 - 4 of 4 Posts
I have a d15b6 in and just bought a b2 for cheap.I want to swap them but all I hear is they just drop in.its a 88 crx hf could I swap the heads so the b6 will run? what would I have to know before a swap?
D-Series Destruction Master
I'd use the d15b2 head, it's 16 valves. Not sure how the power will work out with that and the ECU.
Make sure that you use the HF intake manifold. You can probably use either exhaust manifold, but the DX unit does not have a cat on it.
EDIT: Check the intake ports on HF intake manifold, they might not line up with the DX ports (8 valve may be smaller than the 16 valve, I don't remember)
I'm trying to help, but I cannot remember! :hammer:
1 - 4 of 4 Posts
