OMG TOTALLY COOL TITLE!!!!
88 y49 crx
ok i did a quik search and didnt find anything that would help. will the d15b2 cam gear work on a a6 cam shaft. what happened was the woodruff key was broken off the a6 and the cam gears is completely worthless to me now but the cam looks like it could be salvaged. will it work or no? if not im just gonna swap the motor out and be done with it.
88-95 all the factory cam gears are the same.
But, it's not gonna help, you seized the cam.
When that happens either the timing belt breaks, or the cam gear fails.
You have a larger issue at hand.
88 y49 crx
the cam gear has no chance of being save but the cam is ok i think :S can you pls explain more about what happened to me, i dont know exactly wat happened all i know is the cam key was sheared off and half is still stuck to the cam gear.
