1 - 9 of 9 Posts
Ok I have a D16Z6 motor and I have D15B2 motor,...I tore down the Z6 to find that I have a cracked/gauged sleeve I had already bought ZC pistons and had them pressed on to Z6 rods,....Now that the block is toast I was wondering if I could put the Z6/ZC rod piston combo into my D15B2 block and put my Z6 head on it,...I'am not to sure about the cleances on things so I was hopeing I can use one or the other cranks or thicker head gasket or what ever it takes if I run into clearence issues,...Thanks guys!,....
Well?
nope, rods wont fit. get a new Z6 block or take the pistons back off
Well?
yup. different crank journal sizes, rods wont bolt up.
Well?
nope. your better off getting a Z6 block. P29's in a 1.5 block on the 134mm rods are a waste
1993 Cobra
p29's in a 1.5L only bump it up by about .4-5 compression, whereas a 1.6L will be around 1.75-2.5 compression addition.
1 - 9 of 9 Posts
