1 - 4 of 4 Posts
Ok so I think the pistons HellHatch are selling is a great deal. BUT. Im building a Z6 block for my friend, and he wants to run forged stuff, or vitaras. He told me it is up to me, since i am building and tuning his motor. I would like to chose which ever is going to net power and be safer.
Now dont go saying run Vitaras. I would rather run forged and IF the compression ratio is less than 10.5:1 I will run them. This if for a turbo engine...
So being said. I looked up the pistons for the B7.
The Dome of the piston is -3.4CC and the Compression height is 30.8102mm in a D15B7.
But then in a Z6 is the piston Dome still -3.4CC and then is the compression height still the same, or does it lower. There is a .7mm difference in compression height on the blocks...
Do I add the .7mm difference to the Z6 setup with the custom pistons...?
I am very confused.
Or do I add the -10CC difference between volume size of the Domes?
Here are my numbers...
Z6 setup with Z6 .037 HG with Custom pistons @ -3.4cc & 30.8102mm Compression Height: Static Compression Ratio 11.31:1
Z6 setup with Z6 .037 HG with Custom pistons @ -13.4cc & 30.8102mm Compression Height: Static Compression Ratio 9.19:1
Z6 setup with Z6 .037 HG with Custom pistons @ -3.4cc & 30.1102mm Compression Height: Static Compression Ratio 10.53:1
Z6 setup with Z6 .037 HG with Custom pistons @ -13.4cc & 30.1102mm Compression Height: Static Compression Ratio 8.69
OR do I ADD the compression height difference?
Z6 setup with Z6 .037 HG with Custom pistons @ -3.4cc & 31.5102mm Compression Height: Static Compression Ratio 12.19
AND the CC difference...
Z6 setup with Z6 .037 HG with Custom pistons @ -13.4cc & 31.5102mm Compression Height: Static Compression Ratio 9.73
Please answer with the most educated answers as i would not only like to know what the CR will be but I'd like to know how you know this answer and why. I like to know the technical side of this stuff.
Well?
well if your playing with the numbers on zeal look at where it says piston to deck on the bottm, if its a number with a negative sign than the piston is actaully out of the whole if its positive thats how far below deck it .
Ok i re-read what you said compression height wont change no matter what motor its in, the piston will stay the same, just do what i said above and try ot stay at zero deck or just under
Hm ok. So looks like its yielding
Z6 setup with Z6 .037 HG with Custom pistons @ -3.4cc & 30.8102mm Compression Height: Static Compression Ratio 11.31:1 and it is .032" out of the hole.
Now if I got std length Z6 rods machined down 1mm the piston would be .007" in the hole and have a 10.26:1 compression ratio, which is very doable...
Damn the difference in compression is damn ridiculous. So pretty much there is about a 2point increase in compression from running B2/B7 pistons in a Z6.
Compression raises from 9.24 with a Z6 HG to 11.31:1 on a 9.0:1 Compression JE/SRP...
A stock compression B7 piston is 0.028" above deck and yields 11.71:1 compression ratio...
link to what is for sale isn't listed.
Z6 head may NOT accept slugs sticking up.........but a A6/B7 open chamber head will :)
1 - 4 of 4 Posts
