90 CRX Si with a JDM D15B VTEC/P28/DX trans
I’ve had this engine in my CRX for about 5 years, and I’ve recently noticed an increase in oil consumption. It always used a little, but now I’m adding every week as it gets pretty low on the stick. Not much smoke from the exhaust, except when the engine is over 5K RPM, then it lets out a decent blue cloud. I replaced the PCV since it’s cheap but it didn’t change anything.
I then decided to test compression, and I’m getting great numbers (~225 on all 4 cylinders). Here are the plugs (around 15k of daily driving on them):
Given that the compression numbers are good and the car is running pretty well, I’m guessing I shouldn’t worry about it for now, but the perfectionist in me doesn’t want to leave it alone. Since it mostly seems to be a problem at high RPM, I’m guessing valve seals? Is it worth worrying about right now or better to wait and see if it gets worse? Thanks
