1 - 3 of 3 Posts
I have a d15b head and im pretty sure cylinder 1 has bent valves. Ive done a bit of research and I keep hearing that z6 valves are compatible, and that they are unique and you have to get them from japan. Which is true?
if they fit the rest of the valvetrain it should work since the head is a z6 casting. come to think of it, it's probably cheaper just to replace the whole thing with a good z6 head
If its VTEC, it shares same valves as Z6 (and Y7/8 ). Yea cheaper maybe, but far from good.. I'd suggest you to get some Supertech valves and racing valve job, probably with bronze guides.. I'll cost you a few hundred but IMO its worth it.
1 - 3 of 3 Posts
