1 - 13 of 13 Posts
T
Im trying to see what is better to do, a D15B swap on my 95 dx or a Head swap from a EX/Si. Which one will give me better results and is easier to put in?
Civic, crv, titan
Im not sure on differences in overall HP, it cant be much....but i would think the full swap......especially if your engine has high miles.....the lower the miles the better, odds are the D15B will have the lower miles........
The head swap will be slightly less work, and a little cheaper....
Either way dont forget to buy a p28 ecu for VTEC.....and either way you will have to do some wiring for vtec as well.
T
With a swap like that, what do you need, if you know?
you can also go to www.d-a-p.com and get the number to call them.their prices are good and service is excellent. also you might want to try a vx timing belt ive heard the ex/si belts whine a little because they are tighter. good luck
yellow bar for me
viper blue 92 eg
isnt the vx belt 1 tooth smaller. i used a z6 timing belt and y8 head gasket on my z6/b7 mini me
1 - 13 of 13 Posts
