Ok first off i swapped a d15b into my 94 CX hatch, i swapped wiring harnesses over and will run my vtec wiring when i get the correct ECU, but in the meantime I am trying to just get it running with the stock p05 ECU I also have a p06 but i cant get it running the main problem is im not getting fuel, i removed the bleeder screw and it doesnt seem the fuel line is pressurizing nor does it seem the fuel pump is running, but it worked fine just before the swap...any ideas why the fuel pump would all of a sudden stop working?
