1 - 12 of 12 Posts
R
hey guys i am getting ready to buy a d15b to put into my 91 crx hf...i have been surfing the net for some time now just trying to learn as much as i can. With so much info i was wondering if anyone knew of a good guide to this swap....just loking for something to reduce all this stuff down into guide/parts list.....anything
thanks
Eric
S
well are you doing the D15B JDM Vtec swap or just a regular ol D15B???
Im doing the JDM one, i can help you in regards to your swap.....i need more info like your plans and what the actual motor code is, but if its a D its surely a drop in motor to the good ol HF model.
M
yeh i'd also be interested if anyone can help
my current engine is a d-series dual carb (which has an ecu)
wiring is my biggest problem
R
yeah wiring is also my problem....i plan on using a p08 ecu( i think thats the right one) ...from what i have learned i need a jumper harnes to connect the ecu to the harnes in my car but i also need some way to wire up vtec... thats what i dont really understand... i guess if i use the po8 then all i have to do i connect up the vtec wires....plus i have to change to obd0 to obd1... i am so confused...some one please direct me....thanks
obd0 to obd1 harness
then just find a wiring diagram the shows you which wires go to the ecu for vtec
M
how about wiring a PMFI main relay into a carby harness?
I have the schematics diagram for it but have no idea how to read it
run a wire from a4 to the vtec solenoid
run a wire from d6 to the vtec pressure sensor
run the 2nd wire from the pressure sensor to the chassis
voila!
(honestly, there are a hundred posts on wiring vtec)
M
hi guys reading your coments wondering if u boys cud help me. i hav a civic eg4 d15b3 single carby auto choke on a 91-92 and i want to drop a d15b vtec in it from a eg4 vti wot will i need 2 do example engine mounts,gearbox,ecu,fuel pump etc etc
1 - 12 of 12 Posts
