1 - 3 of 3 Posts
I have a swapped D15B in a 91 EF and it recently started to stutter when it runs under about 1500-1000rpm after putting coolant.I changed the spark plugs, a new pully and alternator belt, and changed the oil. what can be the problem?
91 CRX Si
This may sound odd but did you change out the thermostat? Ive heard of bad thermos causing engines to sputter.
i just checked the oil and it was almost out! I'm putting more oil and going to check the thermostat and going to update on how it goes
1 - 3 of 3 Posts
