1 - 20 of 20 Posts
Hey guys i was wondering if i can stroke my d15b with d17 crank and pistons including the rods i would like to know a lot of info on the how to, because
a) i´m a noob
b) i got a great deal on d17 internals (pistons,rods,crank)
c) i´m from venezuela and don´t have too many options for swap or aftermarket support and want to kill bitches on my little "1.5"
D) i got a dual carbed engine with no ECU and VTEC-E head so i think it´s pretty badass :pedo:
thanks guys :D
Discussion Starter · #4 ·
simple answer....no way.
So if it not gonna work, what can i do to stroke my engine? i have seen d16a6 getting stroker without issues but i would like to do it to my d15b :)
why not just do it and she if she comes alive or not:hammer:
I want to do it bro but i´m scared of doing because here in venezuela everything is so expensive and a replace engine it will be expensive than buying my car again so if it blows :(
Discussion Starter · #8 ·
+1 on the mains. I built a 17 stroker from a z6 with the guidance of dso
so what do you recommend me to stroke my d15b? i´m trying to build something very unique because here nobody has ever build a stroker D series, but i got to work with what i have and all the D17a2 parts are a cheap deal :/
93 EX Coupe
why dont you sell the d17 stuff to someone with an a6 and just go fuel injection and a z6/y8
凸(◕_◕)凸
D16 z6 a6 y7 y8 etc. You should be able to pick up a block for cheap. I find them for fifty or so pretty regularly for just block and girdle
Discussion Starter · #12 ·
yeah bro in the states but here in my country our economy sucks and z6 swaps can cost same price as a k20 swap in the states :( but i changing my mind on stroker and build an all motor with stock internals. :D
i wish i could but i can´t because as i say it before parts are hard finding and a full fuel injection swap is really expensive and harness and ecu are nearly unicorn parts, here only big money guys and shops build sick rides and most of them are D-Series :/ if got a lot of money you can do a B swap and if you are rich you can go K,J,F and H :(
It sounds like you need someone stateside to buy parts for you. Even with shipping it sounds like you would come out cheaper.
I paid less for my entire car than a K swap would cost.
shit I paid less for it than a decent GSR or B16A swap costs :lol:
short deck and long stroke NEVER work together, EVER!
Discussion Starter · #18 ·
hey guys i´m back the project is still going on but stroker is not a option, she is getting all motor build on oem internals, after a teardown i came to the crankshaft only needing to take out the flywheel and 2 little pieces a Thrust washers i think how it´s called came down, what are they function? did i need them?¿ i never have been seen that is my first engine build so i´m really really noob don´t be mad at me :)
Discussion Starter · #20 · (Edited)
Yes thrush washers are needed, they prevent the crank from "walking" (front and back movement of crank).
thanks bro :) but what would be the correct position of them? since they came out alone when the damper was removed :) i´m looking now to how many torque lbs need the all the elements when get assembly together again :D
later i will upload some pics and will change the thread to rebuild thread :p
here is my nwp4life build thread and constant progress on my car :) http://forums.nwp4life.com/zerothread?id=41760 any ideas and critics are welcome i have almost done all the autobody and stuff to my car, is my first build and basically learning how to do everything :D
1 - 20 of 20 Posts
