Hey guys,
Im kind of new to honda and to this forum and have spent a good few weeks reading up and learning alot about the D-series. This is an awesome site.
Now i have a questions, i've read and read and read and searched the web and the forums here on which axles i should use for the D15b OEM LSD tranny. Most of the posts about OEM LSDs are for the ZC tranny and there were a handfull for the D15b LSD. the best i've come up with is to either use my axles or to use a 86-89 axles. Does that seem correct to you? can someone please chime in?
btw i have a 95 Civic HB with a D15b Vtec motor going in, in a few weeks. So im just trying to get all the parts needed. Only part i have left unanswered is the axle.
92 Civic Hatch
Only time i know of having to get different axles, is if you swap a different series motor and trans into your car, and sometimes not even then. Its just a matter of difference of spline count for the transmission and the spline count on your hub.
97 EJ6 boosted D16Z6
the hydro jdm lsd d15b trans uses the same axles.
its an s20 EX\Si trans with a different differential.
26k+, no issues
