1 - 1 of 1 Posts
I've just finish my d15b swap into my 93 sol . Car is running like 40% cooler than the z6. On the temp gauge on the cluster 0-10 ( 10 being the hotest) i 'll say 3.
1- is it ok that my engine runs cooler than my old z6? (that cooler!)
2-Does it make a difference if you have more coolant/antifreeze than normal?
I mean like only 10-20 % of water instead of 30-50%. Because that's is what i might have. Can that be the reason why it's running cooler. Just wanted to let you about my coolant/water ratio in case that can be a reason.
I really need help.
Thanks
1 - 1 of 1 Posts
