1 - 6 of 6 Posts
K
I just purchased a D15B for my 1992 Civic Hatchback. I have a Greddy TD4 on my D15 right now. I have blown rings on my current motor and that's why I had to purchase a new one. My question is this, what should I do to my new motor before installing the turbo kit. I want this motor to last me a long time. I haven't installed my new motor yet. Sorry about the noob question. Thanks for your help.
K
I know I have to do a tune-up, change waterpump and timing belt...
jdm d15b vtec? or some other d15b?
if you want it to last, as diz said, get it TUNED and tuned RIGHT
dont fudge around with shitty fuel management.
you're going to need bigger injectors for sure, so go find some 450cc's or something.
also 2step colder plugs are good to have.
and yeah,
find a good tuner
injectors are fine for the h/p made by that kit, if its the whole kit, that comes with the greddy emanage, than its fine, no other tuning is needed, and plugs are not needed, the oem ones are fine, you can get new ones if you need them, ngk's are good, reliable, but other than that, get your water pump timing belt maybe do some seals, rear main and cam shaft seal, among other things, ummm.. thats about it, anyone have anything else to add
1 - 6 of 6 Posts
