1 - 12 of 12 Posts
can i swap over internal parts from other motors or is there a website were they sell internals on my jdm d15b, like the rods, aftermarket piston heads, cams, retainers, studs. anything would help.
2009 tacoma 4x4
internals for the head will be the same for the D16Z6. rods will also be the same, but pistons will be different...(hint-the d15b has a piston height of 27mm, compared to the 30mm of the d16z6)
rods are the weak link
spend the money while it's apart
fjdistributors.com
The website says those rods are not for N/A engines designed for boost and modifications may be needed to use them. Seems like a lot of work if not doing a big boost setup. I am in the process of putting the D15b in mine now, sticking N/A so I will leave it as it is.
2009 tacoma 4x4
if going force induction, and high boost id recommend aftermarket rods. but if your staying N/A, and you tune is good, theres a good chance you wont be able to break the stock rods. also, aftermarket rods require block modification.
i heard the d15b internals are near bullet proof and they can handle a lot thats if u have the 3stage d15b though i think i remember reading it some where ill look for the link but still not the same as aftermarket i bet and the cam on the d15b is suppposely the same as a gsr cams again i read this some where
2009 tacoma 4x4
a 3stage d15b is actually a gas sipper, so i doubt it has anything similar to do with a GSR.
1 - 12 of 12 Posts
