1 - 7 of 7 Posts
ummph i little bit confuse here.. what should i choose to replace my stock head...
d15b head or d16z6 head or maybe y8 ???
what the different ? and how i determine the difference between d15b,d16z6, n y8 from the outer skin
oh yeah my engine is d15a Vtec ( my car is honda city type z ( SX 8) '02 ,and its only for ASEAN market ,i know one thing that in JDM and USDM there is not d15a with Vtec.. but i have,thats all i know )
thx
all that i know if its d15b 3stge Vtec.. there are 2 vtec solenoids.. d16z6 have only 1 solenoid same as d15b sohc vtec at early production
but.. if i choose 3stage vtec.. i must change my ECU too if i want the "3stage" active
96 hatch SIR
No, not exactly U can slap on the single solenoid vtec on ur jdm15b head and run with the p28 ecu butta, u won't get vtec untill 5500 and when u do It'll be as noticable as a b-series thats cause u don't have all 16valve engaging untill 5500 (where its supose to only have 12valve engaing and vtec at low rpm and swhitch to mid and high rpm with the dual solenoid).
96 hatch SIR
Let me rephrais that vtec engages at 4500 not 5500 I fogot that was when I was obd2 when i used the pigtailo adapter to the p28 vtec kicks all the way to 7500 iono kinda wierd butta it did with the stock ecu. Th e difference is that the jdmd15b head has a more agreasivier cams.
Discussion Starter · #7 ·
hmmm... d15b have more agresive cam ya ?
but.. from the outer skin/ phisics, how can i determine which is d15b and which is d16z6.. ? is there some 'mark' on them maybe ?
thx
1 - 7 of 7 Posts
