J
i have the d15b (jspec) engine and im goin to boost it. cant find a forged piston for it. any out there? ir will another family member engine code work?
really? that intrests me
always thought you could get some d16 pistons and rods for the JDM version B/C of the crank be soooo special
QUOTE this is from raceeng.com ~idunno wat meens jdm or usdm
SR-149184 HONDA 1.5(D15B)FT:75mm/9:1 $380.84 SET Check Availability
but where would you get stuff for the D15B7 ????
that is what intrests me
all i had found for it were some overpriced rods by *searching* for around 700$
transzex said:
for D15B? no one has even comfirmed the compression height yet.
do you meen privately? or like some company or sumthin?
i had also reaserched this extensively a while back and i found out that swapping a D16 vtec for 300$ and some eagal rods and some pistons by wesco would be cheaper than building the d15b7 by a few hundred
+ on top of that the valve train on the 1.6 is sturdyer or so ive heard
but i had seen a orange d15b7 with 500 hp or something like that rolling around somewhere
