I have just finished putting everything back together after replacing my timing belt. I insured i lined up both TDC on the cam shaft and crankshaft and turned over my engine by hand to ensure everything was in time internally and no knocking was happening between the valves and the pistons.
Now it has come to timing the distributor however i cannot even get the engine to turn over for more than 1 second. Because of this i cannot even get a chance to begin timing it with a gun. The sound is best described as first like the engine is knocking internally causing it to jam only to fade into the sound of a flat battery.
However it cannot be knocking. As as soon as i take out my spark plugs (leaving all the distributor+leads etc in) the engine turns over fine even shooting petrol out the spark plug shafts)
So this can only be a problem of the distributor timing right? Any suggestions on what i can do to get it to turn over long enough to time it? I have tried adjusting the angle of the distributor many times, only to get it turn over about 1 more revolution.... obviously not long enough
I am a first time forum(er?) and forgive me if this is answered somewhere else i couldn't see it. Many thanks in advance. Hope i can sort this out before Friday as someone is driving long distance to purchase and pick up my car this weekend :S
