No one around me will quick job repair these crank snouts, and for the following reasons.
If you do weld the snout, you MUST grind off the outer case nitride layer first.
All Honda cranks are nitrided, and have a very thin hard layer about 0.001-0.004" built up on the surface.
If you dont cut the nitride layer off before welding, it will contaminate your weld. It will be very difficult to TIG weld if you dont get all the nitride away from the area to be welded.
The heat from welding may also compromise the structural forging of the snout parent metal. The keyways and balancers on these cranks are barely on the snout itself, hanging like 1/2" off the end of the snout, which is ridiculous in the first place, but Honda got away with that because of how good their forging process actually is. When you weld and add heat, the forged properties begin to disappear, and weird stresses between the snout and the rest of the crank could appear.
For these reasons, no crankshaft shop or machine shop near me will touch welding Honda cranks without also opting to get them re-heat treated, re-nitrided and re-machined. And I dont blame them, their name is on their doors, and they arent going to tarnish their names for a quick "might fix it" on some honda boy's crank lol.
Because of this, I opted to fix a crankshaft keyway that
@Oldcivicjoe donated to me by using carbides to cut a notch out of the crank, then fill in the space with a piece of keyway stock from a hardware store, then using some Loctite 660 to fill the gaps.
I then shaped the little piece of metal with a grinder and a file to follow the profile of the crankshaft curve as well as build a new wall for the balancer key. The balancer slipped right on, and the keyway fit perfect.
