I got this 4 door from my cousin and she was the original owner and a motor was put in,but I need to know what kind of d15 is it.The black code is just d15 no b7 or anything and it has some block off plate on the back of the head like a vtec solenoid should go there.Only reason I ask is because the plug wires are on the back side of the vc.Anybody got specs for this motor and if it is supposed to be vtec.I don't really know about honda's im a dsm'er.Vtec or not it will be getting 10 psi of boost put to it.
the block off plate is probably for the mechanical fuel pump.
look on the head for a casting code. search the head code or post it up and we will see if we can help you.
Is there anything different between the two power wise because i've beten stock ls dc integras and bolt on vtec cars.
