ok i heard something about the d15's not having the holes drilled out for the zc tranny int. shaft. is this true or any write ups or info nwould be appreciated. thanks in advance
if i put in an SI diff intpo the zc tranny that elimates the whole shaft...? i just really enjoy the equal length axles...it makes me feel like perfect for some reason. just a mental thought. hrmm looks like i gotta find an si tranny then and swap around some gears
i was gonna ask that next bone...my goal was d15b trying to get it low 14's shoot for the stars for a 13.9 heh so is there a final drive bigger than a 4.2 stock that i can throw into a 4g cable tranny?
Ok so I’m trying to tension the power steering pump where it needs to be and realized the car didn’t have part of the items needed to do so.
My question is what other piece do I need to complete this so it will stop squealing randomly?
Portion missing is piece that the wingnut bolt threads into...
So I'm going to start that I need a new starter and dizzy for sure but cause I hook up a z6 harness to a y7 block ? And I'm thinking about just getting a z6 block and putting it in
Need a second opinion here:
I have an 89 CRX Hf that had working AC, not amazing, but it worked. I assume it was R12 as there were no converter nipples going on.
A while back someone hit let head on, broke the radiator and mangled the condenser, but didn't rupture it.
I decided since I was...
