1 - 7 of 7 Posts
hey guys hows it going? you guessed it by the title, im seeing if there any on here htat have built one of these "d15 strokers". I am haveing trouble finding threads on it, so im guessing not alot of people fool with these. I just heard from a reputable builder freind of mine that it can be done and has, so any info on putting d16 rods and crank into a d15 would be much appreciated.
i belive d16 rods are three mm longer than d15 rods. I dont think you would have to notch the block for the rods, but your R/S ratio would be horrible. i would be amazed if you got that engine over 6krpms without throwing a rod.
shorter deck D15 doesn't need a stroker setup.
If ANYTHING, main bearing spacers to run a D15B crank in the taller D16 block, then longer than stock Eagle B18 rods slimmed to fit D crank and pistons.
im currently putting together a d16, i just want to see if there is any use for my d15. Aftermarket rods are just to pricey, compared to a d16 so im trying to find what its good for, if anything at all.
D15's aren't used for much right now. Your pretty limited with lower end parts.
unfortunately ur right, lol i still wanna try somrthing different with a d15 one of these days;)
1 - 7 of 7 Posts
