1 - 3 of 3 Posts
I have done a semi rebuild on a d15b2 and was not getting heat so I changed my thermostat and flush the heater core and still no heat I let it run for a awhile then started to overheat. I felt the hose that leads to the heater it is getting hot. I would like any input or comment on what I should try or do thanks
91 Civic
cant bleed the coolant properly if you cant get the heater core flowing, it cause an air bubble and it keep finding its way to the head.
1 - 3 of 3 Posts
