1 - 9 of 9 Posts
ok, im a noob to d-series but not to hondas. I have a d15 bock rebuilt with a z6 vtec head with a chipped p28. I have done three civic engines but never done a turbo.
my idea is to get a t3 or t4 turbo kit. now I know the d15 rods are like pencils but would I be ok to run 7lbs of boost if tuned properly?
I don't want to burn it up or spin a bearing either
any advice would be great thanks alot.
Seems like you need to do some homework before you set off on your project.
Ill give you a quick run down.
Psi doesnt break motors tq does.
d15b7 rods are normally good for around 180hp/170tq
The number in a turbo doesnt always say how big it is. meaning a t2 isnt always smaller then a t3 etc... but it kinda goes like this. A big t2 can be the same size as a small t3 same with t4.
Imo for stock block t4 is to big.
Also you need a power goal and budget before you can even get started.
Then is it street or drag?
Can't wait to see you get started on your project I'm almost don't with mines it's in my sig check it out if you'd like I was the same way I built so many ITR's N/A but never turbo besides owned turbo cars that came stock with turbo so had some turbo knowledge but not on a Honda way different than a turbo German cars but good luck youll have fun with your build.
i had a few questions myself about adding a turbo. i have the same engine, and dont get me wrong their quick enough to get to where u want to get to, but more power would be bomb.
ok, well i suppose i will do some more research before i put a turbo on. what other things could i do to get more power?
--i already have a cold air intake' who doesnt lol
--also i know an ex tranny would help as mine is dx
Not always about what u cam do vs price. Its cheaper to boost.
You can port and polish the head. Mil the head and change pistons to up the compression.
Get a cam and run lager valves. Then tune it.
But it will cost more then a turbo kit and your be at less hp.
1 - 9 of 9 Posts
