1 - 6 of 6 Posts
HONDA
Okay so i crashed my EK the other day. had a chance to look at is this weekend and repair some of the damage.
Honda ZA - civic parts needed - crash pic's added - Honda Racing Club - South Africa's largest Honda Forum
motor starts, took some time to fire up first time but now it starts no problem. idols 100% normal, but as soon as you give it gas it boggs down, for a few seconds then revs up normal. took it for a drive up the road and as soon a you driving you have to rev it hard to get little power out of it.
cam timing is correct but was unable to check ignition timing. comp check #1=800psi #2=780psi #3=800psi #4 830psi which should be fine. need to do a leak down as well just to be sure but that all seems right.
i have changed the plug as well on it.
ideas?.... oh and the battery was flat had to jump start the car.
Reactions: 99ctrhatch
HONDA
bump
HONDA
yep it had... just fixed it now... i dont know where my head has been over the last 3/4 days... some of the simple thing im over thinking...
1 - 6 of 6 Posts
