1 - 3 of 3 Posts
hi.
i build d14a4 turbo and i have problem with the obd1 distibutor....
when i line up the distributor house holes with the head the engine wont start but..... when i retard it too much the engine start but the distributor house holes is far from the head holes.
p28 ecu
td-41u distibutor
96-98 d16y8 loom convert to obd1 distibutor.
toy truck, sidekick,
You can pull distributor cap and mark distributor body move 1 tooth back on cam gear(mark t.belt/gear. See if it is within bolt up alignment. If it is try it. If you can find cam gear t.belt/crank tooth count would be next to check I think. My d16 use different belts 104 106 z6 y8 and d16a6 cam mark is advanced 1 tooth below head horizontal position. Something is aligned wrong(obviously).
1 - 3 of 3 Posts
